5 years agoCatalyst II
Hi Miraks,
newResult can just return text. Maybe you can add your output to a temporary Aras item and then return the item?
miraks
5 years agoCreator II
Hi Angelalp,
Thank you for your answer.
If my method is like this:
return this.getInnovator().newResult(new Newtonsoft.Json.Linq.JObject
{"return_code", 0} ,
{"message", "hello world!"}
}.ToString(Newtonsoft.Json.Formatting.None));
The output is a text:
var item = this.getInnovator().newItem();
item.setProperty("json", new Newtonsoft.Json.Linq.JObject
return item;
So, you are right, with your solution the output is well a JSON.
But a JSON of an Item. Is it possible to send a fully customized JSON ?
Regards.
Hi Miraks,
standard Aras Method just can return items. "Results" and "Error" are also just items.
Maybe you can use some kind of custom class or other more native C# techniques, but I am not sure. Some times you see these kind of designs in native Aras code.
