Amitosh_Tripathy's avatar
How to render a boolean field in a form as HTML with images or colored text
has_change_pending in Part/CAD/Document forms is a check box. I want to make it
- An image, if true show one image, if false show another
Or
- A colored text, if true show in one color, if false show in another color
Trying with making the field as HTML and add some tags, not much familiar with them, so wanted to ask here.
  • asebastian's avatar
    asebastian
    Hi Amitosh,
    This is an interesting use case. I'd recommend looking at the OOTB form for an Express ECO. There is a field on the form titled "EDR_Status" which is very similar to what you're attempting to do. All manipulation of this field happens during the form's onFormPopulate event "Express Fill EDR Status Field". Specifically, the function "populateEdrStatus" will be helpful.
    You should be able to write some javascript which quickly looks at the boolean property, and then assigns the correct image/text to the HTML element you've created.
    Tanks,
    AJ
    • Amitosh_Tripathy's avatar
      Amitosh_Tripathy
      I could change the field to HTML,
      <img src="../customer/ChangePending.png" style="width: 36px; height: 36px;" name="has_change_pending"></img>
      And wrote a method on onFormPopulate to decide to show the image or not
      if(top.aras.getItemProperty(document.item, "has_change_pending", "") != "1")
        hideChangePendingImage(true);
        return;
      hideChangePendingImage(false);
      function hideChangePendingImage(hide)
        var image = document.getElementsByName("has_change_pending")[0];
        if(hide)
          image.style.display = "none";
