angela's avatar
How to pass additional custom parameters in Form call?
Hi Community,
I want to launch a custom Form from an CommandBarMenu CUI event. Users can select multiple items in the grid and then click the CUI button. Then a form shall open up in which users can do certain operations with the selected items.
I want to pass the id´s of the selected items to the launched Forms. But I right now didn´t find an elegant way to pass the idlist or multiple items. I right now create a temporary item, but I am not very happy with the solution. I somehow think that passing custom paramters to Forms should be possible. I just don´t know how.
Does anyone of you know a solution? My main problem is not the actual passing of the custom parameters. But I don´t know how to retrive it later.
Here´s my current code;
var idlist = options.selectedRowsIds;
var inn = new Innovator();
// Create temporary item to pass idlist (workaround!)
var tempItem = inn.newItem("Part");
tempItem.setProperty("_idlist",idlist);
// Launch Form
var topWnd = aras.getMostTopWindowWithAras(window);
topWnd = topWnd.main || topWnd;
var params = {
title: 'do something',
item: tempItem,
formId: "9336D7E4DD244391AEC9593DD8A5D85B"'
aras: aras,
//innovator: this.getInnovator(),
dialogWidth: 1200, // set width int
dialogHeight: 600, // set height int
content: 'ShowFormAsADialog.html',
idlist: idlist <<<<<<<<<---------------------------------------- // is it somehow possible to pass custom parameters with the form to avoid the tempItem? And how to I get it?
Thanks for any ideas!
  • Add the below code to your Aras method. Hope this helps
    wnd.ArasModules.Dialog.show('iframe', params);
    -----in your ShowFormAsADialog.html---------------------
    addd this line
     var  args = window.frameElement.dialogArguments; // get the params from Aras method
    addd this line
      Hi Truc,
      many thanks for answering this question! It´s already a few month old and till today I used the workaround cause I didn´t know a better option.
      I instantly tried your variant. In my case I had to use 'parent' instead of 'window'
      var  args = parent.frameElement.dialogArguments; // get the params from Aras method
      It worked perfectly and I was able to get my custom values from the passed Form parameters.
      I really like this one - thanks again!
    • medurisrilekha's avatar
      medurisrilekha
      Hi Truc,
      I have tried this  to add custom parameters
      var param = {
      aras: top.aras,
      type: 'SearchDialog',
      dialogWidth: 700,
      dialogHeight: 450,
      itemtypeName: 'sb_Sample',
      multiselect: true,
      sourceItemTypeName: 'sb_Sample',
      sourcePropertyName: 'sb_filter_action',
      parentItem:thisItem1,
      productTypeVal:productType,
      itemContext : testDefArray
      };//Test Definition Param
      var topWnd = top.aras.getMostTopWindowWithAras();
      var wnd = topWnd ? topWnd : window;
      //opening Test definitions search dilog
      wnd.ArasModules.Dialog.show('iframe', param).promise.then(callback);
      And to get the value to filter in other method
      I added:
      var m_parentItem=inArgs.parentItem;
      var m_productType=inArgs.productTypeVal;
      But I couldn't able to get the value in another method to filter can you check is there any wrong in this code
      • Truc_Nguyen's avatar
        Truc_Nguyen
        It seems you missing --> content:
        var param = {
        aras: top.aras,
        dialogWidth: 700,
        dialogHeight: 450,
        multiselect: true,
        content: '../customer/abc.html' // Put path to HTML file here,
        In the abc.html file , you can catch the variable passed from the triggered method you call.
        I'm not sure what you are trying to do in your case, but inArgs is the context variable you get from the event, I could be wrong.
        wnd.ArasModules.Dialog.show('iframe', param).promise.then(callback); // this line of code creates another thread which runs abc.html
