Gopikrishnan
7 years agoAccelerator II
Hi Zachary
You can change the visibility in Client Presentation. Follow below steps
Step 1: Administrators --> Configuration --> Client Presentation
Step 2: Click Global hyperlink
Step 3: Navigate to Command Bar Section tab
Step 4: Search for com.aras.innovator.cui_default.main_window_main_menu
Step 5: Double click to Open
Step 6: Lock the Item
Step 7: Navigate to Command Bar Item tab
Step 8: Search for com.aras.innovator.cui_default.mwmm_change_passwd
Step 9: Change For Identity to Administrators from World
Step 10: Save, Unlock
Let me know if it helps.
Thank You
Gobikrishnan R
