Gopikrishnan
5 years agoAccelerator II
Hi
I don't find any easier way to achieve this. But you can use below workarounds.
Workaround 1
Create below Javascript method and attached to Relationship Grid Event (On Select Row Event)
var isItemLocked = aras.isLocked(parent.item);
if(isItemLocked)
alert("Editing is not allowed");
return false;
Workaround 2
Attach the above method to all the visible properties in relationship (On Edit Start Event)
tenny
5 years agoIdeator III
Thanks it works in Workaround2.
