Florent's avatar
Florent
4 years ago
How to increase getFileURL token lifetime
I am currently writing a server method which will provides some data including file urls to our MES.
To get file url I'm using the method innovator.getFileUrl(fileInfo.FileId, UrlType.SecurityToken)) that returns something like vaultAddress/vaultserver.aspx.
The problem that we are currently facing is that the link bellow is valid only 2 minutes, so if the MES operator doesn't click on the 2 minutes, the file won't be downloadable.
So I was wondering if we can increase the lifetime of the token and how can we do it ?
Regards
Florent
  • Hi Florent,
    which Innovator version are you using? I don´t know the exact solution, but the various  oauth.config files in the codetree allow you to specify a "tokenLifetime" and "duration". The typical value is 300, not sure if this matches your 2 minutes.
    I would try to change VaultServer/oauth.config . But I am not sure if this one is really the correct file for this change.
    • Florent's avatar
      Florent
      Hello Angela,
      Thanks for your answer.
      I have already try to increase each value of oauth.config on vault and oauth server but nothing seems to work ...
      We are using version 12sp11.
      Florent
        There are other files inside Vault and Oauth that may contain some timings, but I am not sure if they are really the correct one.
        This one seems to specify the general time out for the Innovator client:
        ..\Client\Modules\aras.innovator.AuthenticationFramework\Scripts\OAuthClient.AuthorizationCodeGrant.js
