Hi Florent,
which Innovator version are you using? I don´t know the exact solution, but the various oauth.config files in the codetree allow you to specify a "tokenLifetime" and "duration". The typical value is 300, not sure if this matches your 2 minutes.
I would try to change VaultServer/oauth.config . But I am not sure if this one is really the correct file for this change.
Hello Angela,
Thanks for your answer.
I have already try to increase each value of oauth.config on vault and oauth server but nothing seems to work ...
We are using version 12sp11.
Florent
There are other files inside Vault and Oauth that may contain some timings, but I am not sure if they are really the correct one.
This one seems to specify the general time out for the Innovator client:
..\Client\Modules\aras.innovator.AuthenticationFramework\Scripts\OAuthClient.AuthorizationCodeGrant.js
- Florent5 years agoIdeator I
Thanks for your research Angela.
According to the support this value is hardcoded and equal to 100 seconds.
Since 12SP18 new operation parameter key (named FileDownloadTokenLifetime) was introduced into InnovatorServerConfig.xml
Thanks for the information! This one was an excellent question and I was also interested to know if there is a solution.
Do you know if the new operation parameters key are contained in any of the newer documentation guides? Or do we have to ask for them? I right now have a 12SP18 test installation running, but my Server config did not contain this parameter.
