frank_guarino_murata_com's avatar
1 year ago
How to import javascript classes into another javascript method?
I have a JavaScript class which I created and I want to instantiate this class in another javascript method
i.e.
F2:
export
default class Example { test() { console.log('hello world'); } }
& F1:
import
Example from './file2';
var myInstance = new Example() myInstance.test()
I have not been able to do this yet, and I'll likely need to find another way, but does anyone know? I am aware of aras.evalMethod, although I have yet to find success in terms of class instantiation with this way.
    Hi Frank,
    good question! I so far didn´t succeed to use anything with "export" in my code.
    Currently I use following two ways to embed external libs:
    1. https://aras.com/en/blog/display-workflow-timeline-using-vis-js - See code sample
    2. If the concept shown in this blog post code doesn´t work for whatever reason, I directly embed the class in the Form inside an html element. This works always. But I prefer the variant in the blog post, cause custom libs references in Methods are easier to see.
