How to highlight a relationship tab
Hi there,
I'm looking to highlight certain relationship tabs (say the Documents tab under a Part item). Now I've found controls to edit the CSS of various fields of the Part form, but I haven't been able to figure out how I can for instance change the background colour of the Documents tab label (in order to pull a users attention towards it, for instance).
Is it at all possible to dynamically change the look of that particular piece of the form (by firing a method on the onLoad and/or onFormPopulate events for instance), or are those controls entirely inaccessible?
Kindest regards,
Remco van Oosterhout
this project shows how to do static coloring of tab labels:
https://github.com/ArasLabs/set-tab-color
The project contains an open issue with some samples for dynamic tab coloring, but it´s still a draft. Would be happy if you could share your experience. Maybe you have some additional ideas?
https://github.com/ArasLabs/set-tab-color/issues/1
Regarding your second request to color Form elements dynamically: This one is different form coloring the tab elements. Regular Form events should already work. Take a look at this thread:
https://community.aras.com/f/development/3502/how-to-auto-change-the-label-color
