- Yoann_MaingonAccelerator II guess this : ' or this : ' should work !
- AabaIdeator III<AML> <Item type='Part Item Characteristic Value' id='11111111111111111111111111111111' action='edit'> <item_characteristic_id>11111111111111111111111111111111</item_characteristic_id> <display_value>Aras Value's</display_value> <item_characteristic_value_type>List</item_characteristic_value_type> </Item> </AML> This returns error as <faultstring>Values cannot contain the ' character</faultstring>. As per your suggestion i tried ' and ' as well. Not worked :(
- Yoann_MaingonAccelerator IHow do you test this? Is this generated in a method? Do you have any Regular expression defined on display_value ?
- AabaIdeator IIIYour guess was correct :) I found server event for this which was causing issue. Thanks for your help.
