8 years agoCatalyst II
How to get the workflow of a change item programmatically?
I want to run the following client code from an Express ECO button event:
var innovator = new Innovator();
var thisItem = document.thisItem;
var id = thisItem.getID(); // id of Express ECO
// here should be the code that fetches the Workflow Process id.
var qryItem = innovator.newItem();
qryItem.loadAML(
"<Item type='Workflow Process' id='/*----missing ID----*/' initial_action='get' action='do_l10n' select='state, name,related_id(name)' >" +
"<Relationships>" +
"<Item type='Workflow Process Activity' action='get' select='related_id'>"+
"<related_id>" +
"<Item type='Activity' action='get' select='name,related_id(name)'>" +
"<state condition='ne'>Pending</state>" +
"<Relationships>" +
"<Item type='Activity Assignment' action='get' select='related_id' >" +
"<related_id type='Identity' select='keyed_name' />" +
"</Item>" +
"</Relationships>" +
"</Item>" +
"</related_id>" +
"</Item>" +
"</Item>"
var resultItem = qryItem.apply();
Unfortunately I wan´t able to find the missing link between the Express ECO and the corresponding Workflow Process yet. Can you give me a hint how the two are connected?
Thanks again!
