Hi Nathan,
thanks for your answer! The idea of using QueryDefinition was based on the Multilevel BOM Report.
I so far discovered we have two variants of the Multilevel BOM Reports:
1. The Innovator 11 variant where everything was solved with XSL/XSLT
2. The Innovator 12 variant which mixes XSL/XSLT, QueryDefinition and a few additional Methods to build the Report.
In Innovator 12 key element is PE_ExecuteQdReportMethod . It calculates depth and levels, but it´s hardcoded to certain reports. And I don´t want to use 400 lines of code just to get a simple "level" information within a regular AML query.
I wonder if the Innovator 11 variant is easier to reuse. My problem: I don´t understand the Stylesheet and XSL stuff and I don´t know how to reuse the result in a Method.
One other totally different variant would not to use an AML query, but an SQL CTE function. This is how MPP calculates levels.
So I right now have many variants, and all of them are just super hard to do. I am still searching for the holy grail....
Angela,
Here is the code for the Multilevel BOM Report (v11). The repeatTimes statement tells it how many times to go through the process.
AML
| <Item type="Part" action="GetItemRepeatConfig" select="item_number,name" id="{@id}"> <Relationships> <Item type="Part AML" select="state,related_id(item_number,manufacturer)"/> <Item type="Part BOM" select="sort_order,quantity,related_id" repeatProp="related_id" repeatTimes="6"/> </Relationships> </Item> |
The Stylesheet (XML) side is something I have had problems with too. There isn't any good info on how to structure it for Aras. I have had to do a lot of searching and deconstructing what was already in my system to make things work. This shows the use of $Depth to test for information. You should be able to use this to test for the depth and assign a style to give each depth something different, or put it in a different column.
Stylesheet (XML)
| <xsl:stylesheet xmlns:xsl="">www.w3.org/.../Transform" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:exslt="">http://exslt.org/common" xmlns:aras="">http://www.aras-corp.com" version="1.0" extension-element-prefixes="exslt"> <xsl:output method="html" omit-xml-declaration="yes" standalone="yes" indent="yes"/> <xsl:template match="/"> <html> <head/> <style type="text/css" userData="Global"> table {empty-cells:show; border-collapse:collapse;} th {font-family:helvetica; font-size:8pt; padding:2px; border:1px #000000 solid; background-color:#CCCCCC; text-transform:capitalize;} td {font-family:helvetica; font-size:8pt; padding:2px; border:1px #000000 solid;} td.noBorder {font-family:helvetica; font-size:8pt; padding:2px; border-width:0;} </style> <body topmargin="50" leftmargin="50"> <table border="0" cellspacing="0" cellpadding="0" width="650"> <tr valign="top"> <td class="noBorder" align="left" colspan="9"> <img src="../imagesLegacy/Logos/aras_logo.gif" height="80"/> </td> </tr> <tr valign="bottom"> <td class="noBorder" colspan="8" style="font-family:helvetica;font-size:15pt;color:#DA1943;padding:2px;" align="left">Bill of Materials Report</td> <td class="noBorder" colspan="4" style="font-family:helvetica;font-size:10pt;padding:2px;" align="right"> Generated on: <script>function m00(r, n){r += ""; if (!n) n = 2; while(r.length < n){r = "0" + r;} return r;} var dt = new Date(); var a = top.opener.top.aras; if (a){var s = m00(dt.getUTCFullYear(),4)+"-"+m00((dt.getUTCMonth()+1))+"-"+m00(dt.getUTCDate())+"T"+m00(dt.getUTCHours())+":"+m00(dt.getUTCMinutes())+":"+m00(dt.getUTCSeconds())+"+0000"; s = a.convertToNeutral(s, "date", "yyyy-MM-ddTHH:mm:sszzz"); s = a.convertFromNeutral(s, "date", "short_date"); document.write(s);}</script> </td> </tr> <tr> <th colspan="6">Indenture Level</th> <th>Part Number</th> <th>Name</th> <th>Quantity</th> <th>AML Status</th> <th>Manufacturer</th> <th>Manufacturer Part</th> </tr> <xsl:call-template name="rootItems"/> </table> </body> <script src="../../javascript/PopupMenu.js"/> </html> </xsl:template> <xsl:template name="rootItems"> <xsl:apply-templates select="//Result/Item[@type='Part']"> <xsl:with-param name="Depth" select="0"/> </xsl:apply-templates> </xsl:template> <xsl:template name="getChildItem"> <xsl:param name="Depth"/> <xsl:if test="$Depth!=5"> <xsl:apply-templates select="Relationships/Item/related_id/Item[@type='Part']"> <xsl:with-param name="Depth" select="$Depth + 1"/> </xsl:apply-templates> </xsl:if> </xsl:template> <xsl:template match="Item[@type='Part']"> <xsl:param name="Depth"/> <xsl:variable name="rowCount"> <xsl:choose> <xsl:when test="count(Relationships/Item[@type='Part AML'])=0">1</xsl:when> <xsl:otherwise> <xsl:value-of select="count(Relationships/Item[@type='Part AML'])"/> </xsl:otherwise> </xsl:choose> </xsl:variable> <tr> <td rowspan="{$rowCount}" width="20px" align="center"> <xsl:if test="$Depth=0">0</xsl:if> </td> <td rowspan="{$rowCount}" width="20px" align="center"> <xsl:if test="$Depth=1">1</xsl:if> </td> <td rowspan="{$rowCount}" width="20px" align="center"> <xsl:if test="$Depth=2">2</xsl:if> </td> <td rowspan="{$rowCount}" width="20px" align="center"> <xsl:if test="$Depth=3">3</xsl:if> </td> <td rowspan="{$rowCount}" width="20px" align="center"> <xsl:if test="$Depth=4">4</xsl:if> </td> <td rowspan="{$rowCount}" width="20px" align="center"> <xsl:if test="$Depth=5">5</xsl:if> </td> <td rowspan="{$rowCount}" width="120px"> <xsl:value-of select="item_number"/> </td> <td rowspan="{$rowCount}" width="120px"> <xsl:value-of select="name"/> </td> <td rowspan="{$rowCount}" width="80px" align="center"> <xsl:choose> <xsl:when test="$Depth=0">1</xsl:when> <xsl:when test="$Depth!=0 and (../../quantity)=''">1</xsl:when> <xsl:otherwise> <xsl:value-of select="../../quantity"/> </xsl:otherwise> </xsl:choose> </td> <td width="100px"> <xsl:value-of select="Relationships/Item[@type='Part AML'][1]/state"/> </td> <td width="120px"> <xsl:value-of select="Relationships/Item[@type='Part AML'][1]/related_id/Item/manufacturer/@keyed_name"/> </td> <td width="120px"> <xsl:value-of select="Relationships/Item[@type='Part AML'][1]/related_id/Item/item_number"/> </td> </tr> <xsl:apply-templates select="Relationships/Item[@type='Part AML'][position()!=1]"/> <xsl:if test="$Depth!=5"> <xsl:variable name="itemIdCount" select="count(Relationships/Item/related_id[not(child::Item)])"/> <xsl:if test="$itemIdCount != 0"> <xsl:variable name="idForEach" select="Relationships/Item/related_id[not(child::Item)]"/> <xsl:for-each select="$idForEach"> <xsl:variable name="tmpId" select="text()[1]"/> <xsl:choose> <xsl:when test="function-available('exslt:node-set')"> <xsl:apply-templates select="//Item[@type='Part' and @id=exslt:node-set($tmpId)]"> <xsl:with-param name="Depth" select="$Depth + 1"/> </xsl:apply-templates> </xsl:when> <xsl:when test="function-available('msxsl:node-set')"> <xsl:apply-templates select="//Item[@type='Part' and @id=msxsl:node-set($tmpId)]"> <xsl:with-param name="Depth" select="$Depth + 1"/> </xsl:apply-templates> </xsl:when> </xsl:choose> </xsl:for-each> </xsl:if> </xsl:if> <xsl:call-template name="getChildItem"> <xsl:with-param name="Depth" select="$Depth"/> </xsl:call-template> </xsl:template> <xsl:template match="Item[@type='Part AML']"> <tr> <td width="100px"> <xsl:value-of select="state"/> </td> <td width="120px"> <xsl:value-of select="related_id/Item/manufacturer/@keyed_name"/> </td> <td width="120px"> <xsl:value-of select="related_id/Item/item_number"/> </td> </tr> </xsl:template> </xsl:stylesheet> |
Thanks for digging out the Innovator 11 variant!
The GetItemRepeatConfig query is similar to my current start point.
Maybe we can mix the Innovator 11 stylesheet with the Innovator 12 approach as seen in PE_execMultilevelRepAndApplyXslt.
This Method applies a stylesheet to a QueryDefintiion Result to build the report.
I want to avoid the QueryDefinition. But maybe I can apply the stylesheet to the GetItemRepeatConfig result in a similiar way. Something like this:
const res = aras.createXMLDocument();
res.loadXML(results);results = aras.applyXsltString(res, xsl_stylesheet);
}If would allow me to then work with the "result" after the transformation of the data. Not sure if it will work.
- Breton4 years agoIdeator III
hello, ok !
Thanks a lot
