Juanstone
3 years agoIdeator I
To obtain user comment from Lifecycle promotion in Pre server method, you can use the following code:
public override void Pre(LifeCyclePromotionPreEventContext context)
string comment = context.Command.CommandComment;
if (string.IsNullOrEmpty(comment))
context.Cancel = true;
context.Result.Message = "Please provide a comment before promoting.";
Here, the CommandComment property of the context.Command object contains the comment entered by the user during the promotion. If the comment is empty or null, the method cancels the promotion and sets a message in the context.Result.Message property.
Try this once.
