eli_donahue
9 years agoCommunity Manager
Hi Frederic,
The Aras Import/Export Utilities are not designed to handle multilingual data. However, each language pack includes the Language Pack Management Utility command line tool (\tools\I18N\LanguageTool.exe) that can be used to export multilingual labels. Some, but not all, language packs include a batch file that demonstrates how to export data using LanguageTool.exe.
Here are the contents of the sample file from the Aras 11 SP8 French Language Pack: 004-EXPORT-FRENCH.BAT. Note that all variables in the third line are set by the call to SETUP-DEFAULTS.CMD.
SETLOCAL CALL SETUP-DEFAULTS.CMD %SELF_FOLDER%\tools\I18N\LanguageTool.exe -export -config_file:%SELF_FOLDER%\French\ExportConfig.xml -folder:%SELF_FOLDER%\French\xml -log_file:%LOGS_FOLDER%\%LOG_TIMESTAMP%-FrenchExport.txt -server:%DB_SERVER% -db:%DATABASE_NAME% -login:%SQL_LOGIN% -pwd:%SQL_PASSWORD% PAUSEEli
