8 years agoAccelerator III
How to copy a file item when updating
I created item type "myitem" with viewable_file and native_file like Itemtype "CAD". Then, when saving "myitem", I created a method to copy viewable_file to native_file, but it does not work. Could you tell me how to do it?
I would like to do the following things.
1, State before saving - viewable_file: A. pdf - native_file: (none)
2, Change viewable_file to B.pdf and save.
3, State after saving - viewable_file: B.pdf - native_file: B. pdf
I created the following method with server event (On BeforeUpdate), but an error occurred and it did not work.
var view = this.getPropertyItem ("viewable_file");
var new = inn.newItem (view.getType (), "copyAsNew");
new.setID (view.getID ());
var res = new.apply ();
this.setPropertyItem ("native_file", res);
error: Sufficient privilege is not set for 'get' operation.
Server error (On AfterUpdate) also failed with an error.
error: An attemp to copy file (ID = xxxx) after add in the same transaction
How do I get the results I expected?
