Beacause large amount for data result, so performance of method above will slower than SQL query ?
Further: with case as below, process will difficult and slow than more if not used query SQL
SELECT *
FROM ABC XXX
INNER JOIN
(SELECT MP.* ,
(CASE WHEN MN.keyed_name IS NULL Then ‘1’ ELSE MN.keyed_name END) AS MN_keyed_name
FROM Manufacturer_Part MP
LEFT JOIN Manufacturer MN
ON(MP.manufacturer = MN.ID)
WHERE ( MP.ITEM_NUMBER = ‘CPART5566a’ AND MP.manufacturer IS NULL )
OR ( MP.ITEM_NUMBER = ‘CPART5566a’ AND MN.keyed_name = ‘MAKRT5566b’ )
ORDER BY modified_on) YYY
ON(XXX.ITEM_NUMBER = YYY.ITEM_NUMBER AND XXX.keyed_name = YYY.keyed_name)
