Super's avatar
Super
How to Convert Item Type from Non versionable to Versionable
Hello All.. I have Item Type "A" which is not a versionable initially. Created around 1000 records for this item type and now I need to create revisions to this and edited Item type to "Versiona...
  • Hi Super,
    It is possible to convert a non-versioned ItemType to a versionable ItemType. When making a versionable ItemType, you must specify whether the ItemType will be versioned automatically or manually. This is set through the Discipline field which is required for versionable ItemTypes.
    Typically, when you check the Versionable flag on the ItemType, this Discipline field becomes enabled. However, we're aware of an issue with 11.0 SP15 that prevents this field from being enabled on ItemTypes that have already been created. You can follow the steps below as a workaround for this issue.
    1. Open the ItemType you wish to make versionable
    2. Lock the ItemType
    3. Check the Versionable box
    4. Close the tab for the ItemType
    5. Reopen the ItemType from the main grid
      1. You should see that the Discipline field is enabled when you reopen the ItemType
