Joseph_An's avatar
Joseph_An
8 years ago
How to check the value of State in BOM tab of Part?
Hi Expert, When I add components in BOM tab of a part, I need to check 'State' of  each components added using Grid Events in RelationshipType of a Part. Event is 'OnInsertRow'. When I click '+' button and pick a component, javascript needs to capture the value of 'State' (e.g: Preliminary, Released). But, a user can click '+' button one time, and select multiple components. In this case, how to capture each one of them (I mean 'state' of each component)? I used the codes below: var thisRel = tmpThisItem.getItemsByXPath("//Item[@id='" + relationshipID + "']").getItemByIndex(0); var stringthisRel = "" + thisRel; if ( stringthisRel.includes("Preliminary") ) { ..... } But, it seems to fail to get state value from each line of selected components. Instead, "stringthisRel.includes("Preliminary") " search all lines added. Would you help how to solve this issue? Thank you.
  • Hello, Could you please include which version of Aras Innovator you are using? I ran a quick test in 11.0 SP12, and found that the onInsertRow event was called individually for each relationship even if I added multiple Parts at once. Additionally, you can more directly check for the state of the related part by using the sample below.
    var relatedNd = parent.thisItem.node.selectSingleNode("//Item[@id='" + relatedID + "']");
    var relatedState = aras.getItemProperty(relatedNd, "state");
    if (relatedState == "Preliminary") {
    // Run additional logic here
  • Hi Chris,   Thank you for you reply. I could solve the issue that I have using your information. Thank you.
