9 years agoAccelerator III
Hi Eli,
The system properties can be updated using SQL.
I tried following comand:
<sql>Update innovator.Part set created_on = '2016-05-16T13:08:25' where ID='item_id'</sql>
But in this case I need to know the name of the table(innovator.Part). I found that table name is same as Object name. Is it always true for all objects ? If it is not the case then how can I get the name of table for different objects at runtime?
Thanks !
-Ketan.
