eli_donahue
9 years agoCommunity Manager
Hi Ketan,
The created_on date is a system property in Aras and cannot be updated via AML/IOM. If you need to update the dates after loading your data, you will need to use SQL to do so. Some other system properties include (but are not limited to) modified_on, created_by_id, modified_by_id, state, and current_state.
