I suspect a modification of PE_ExecuteQdReportMethod method needs to be made.
I can confirm that updating the Multilevel BOM Report Stylesheet and PE_ExecuteQdReportMethod are the two places to look for adding Reference Designator to the multilevel BOM report!
- cc9115 years agoIdeator III
Hi
Glad you found a solution, is there a possibility for you to help me
I don't see how to modifiy the PE_ExecuteQdReportMethod
Been looking at it but can't figure how (im a mechanical engineer...)
- JMJEngineeringConsulting5 years agoCreator I
I've attached both the original PE_ExecuteQdReportMethod and the modified version. You can use a file-compare between the two to see the changes (I use Notepad++ & compare plugin to do this).
Good luck, hope this helps!
[View:/cfs-file/__key/communityserver-discussions-components-files/3/PE_5F00_ExecuteQdReportMethod.txt:320:240]
[View:/cfs-file/__key/communityserver-discussions-components-files/3/PE_5F00_ExecuteQdReportMethod_5F00_MODIFIED.txt:320:240]
Hi
Thank you so much !!!!!!
It worked perfectly, i am now able to deliver more consistent data to manufacturing dpt.
Again, thank you.
Best regards
Cyrille
