In case if your question is about the search result shows some color in background, check the particular field type background color in form
Thanks
Gopi
- Joseph_An7 years agoCreator II
Hi All,
Thank you so much for your reply.
Due date field is not a required property and it doesn't have Background Color.
I tried to find a configuration or code for this. But, I couldn't.
Would you please give me a tip how to solve it?
Thank you so much.
Is this a custom ItemType in your environment or this something that's included out-of-the-box? Additionally, could you confirm if this background color is showing up in the Form of the item or if it's showing up in the main search grid?
Hi Christopher,
Thank you for your quick reply.
I'm not sure whether it is a custom ItemType or included out-of-the-box.
And it is showing up in the main search grid.
Thank you so much.
