QuietClounds's avatar
QuietClounds
Ideator II
how do I find identity associated with the user by C# or Javar
if I know the login in user ID, how do I get his identity?
Thanks
Qiaoyun
  • I know that the question is a little bit old, but in the newer versions you can try this code (for C#) [emoticon:c4563cd7d5574777a71c318021cbbcc8]
    [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:d5e46790-754f-4456-a1d2-679025cf8013:type=csharp&text=string%20userIdentityId%20%3D%20CCO.Identity.GetIdentityIdByUserId%28inn.getUserID%28%29%29%3B]
  • I wished Aras would have a standard function for this common task. But they haven´t. You have to do this with AML:
    // Get user Alias Identity
    Item alias = inn.newItem("Alias","get");
    alias.setProperty("source_id",inn.getUserID());
    alias.setAttribute("select","related_id");
    alias = alias.apply();
    string identity = alias.getProperty("related_id");
    • QuietClounds's avatar
      QuietClounds
      Ideator II
      Thank you so for your reply. I found out that there is a relationship "Alias" connect "User" and "Identity" Will test it.
      Best!
  • Some update to this one, cause this post is about a common task everybody needs to solve sometimes.
    Even if an Aras employee (Chris "the saint" [emoticon:44ce83dd2c0841729633d585605ccf2e]) and many other liked my code sample, I wonder if we all have overseen a better solution.
    Doesn´t inn.getUserAliases()); do pretty much the same?!?!? Does anyone know more? I am so confused right now.
    • little_legend's avatar
      little_legend
        That´s an excellent one - thank you!!![emoticon:1435ff2429184e17bc948e4f19178e1e] Seems to be a very uncommon function, I just found one reference in Innovator at all. But it´s so obviously useful! Finally somebody found the solution to a 5 year old puzzle!!
    • alderaan's avatar
      alderaan
      In C# there is
      [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:e2beef72-9c93-47a9-96b2-3836df04f639:type=text&text=string%20aliasId%20%3D%20Aras.Server.Security.Permissions.Current.AliasIdentitiesList%3B]
      But you would probably need to check if it contains exactly one id, since it is a "List".
      In Javascript there is:
      [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:d7e55918-f2f3-4d13-beee-15c10dfabeda:type=text&text=aras.getIsAliasIdentityIDForLoggedUser%28%29]
        Hi Alderaan,
        many thanks for the examples! I like both variants and will definitely use them!
