alaxala,
Thanks for responding.
That's what is confusing, there are no errors thrown.
No system feedback at all.
Scott
alaxala,
Sorry ... I closed the reply before I completed the comment.
Using the following AML:
<AML>
<Item type="rh_Oracle_Manuf_Master_Item" action="edit" id="C323F3AB54D84E70B54D895158EE3CB7">
<Relationships>
<Item type="rh_OraMfgMaster_ProdNumNomen" action="edit"
where="[rh_OraMfgMaster_ProdNumNomen].source_id = 'C323F3AB54D84E70B54D895158EE3CB7'">
<RH_PRODUCT_CATEGORY_CODE>K</RH_PRODUCT_CATEGORY_CODE>
<RH_TRADE_BRAND_CODE>T</RH_TRADE_BRAND_CODE>
</Item>
</Relationships>
</Item>
</AML>
When I look at the AML server response I get ....
<SOAP-ENV:Body>
<Result>
<Item type="rh_Oracle_Manuf_Master_Item" typeId="8C4C0C666B564C928824E229F4476D1E" id="C323F3AB54D84E70B54D895158EE3CB7">
<classification>Finished good</classification>
<config_id keyed_name="18287161" type="rh_Oracle_Manuf_Master_Item">C323F3AB54D84E70B54D895158EE3CB7</config_id>
<created_by_id keyed_name="Manufacturing Batch Loader" type="User">7F42F026A2BC4EE99066DD094F3610D5</created_by_id>
<created_on>2023-09-10T22:06:01</created_on>
<rh_mfg_weight_code>LB</rh_mfg_weight_code>
<rh_plm_cre_by_div>AC</rh_plm_cre_by_div>
<rh_plm_description>SMALL - 26 TUBE - 1.5 TON</rh_plm_description>
<rh_plm_has_change_pending>0</rh_plm_has_change_pending>
<rh_plm_major_rev>00</rh_plm_major_rev>
<rh_plm_make_buy>Make</rh_plm_make_buy>
<rh_plm_part keyed_name="RA14AZ18AJ1NA" type="Part">BB42DF0F494D415288532C2323D388B0</rh_plm_part>
<rh_plm_plm_created_by_div>AC</rh_plm_plm_created_by_div>
<rh_oracle_item_id>18287161</rh_oracle_item_id>
</Item>
</Result>
<Message>
<event name="ids_modified" value="C323F3AB54D84E70B54D895158EE3CB7|3A40258510F24D1685B044270F4B296A" />
</Message>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
If I look at the SQL Server Table the only thing that has changed is the [modified_on] property.
I also tried using the ID of the relationship:
<AML>
<Relationships>
<Item type="rh_OraMfgMaster_ProdNumNomen" action="edit" id="3A40258510F24D1685B044270F4B296A">
</Item>
</Relationships>
</Item>
</AML>
Same result.
- alaxala2 years agoCreator III
The property names in the AML are case sensitive. So you must specify them exactly as they are defined in the Aras itemType, not in the SQL table.
- srmorrisonearthlink-net2 years agoCreator I
alaxala,
Wow I can't believe I missed that.
Good catch. Its the simple stuff that ....s me.
Thank you
Scott
