Administrators can specify History Templates for each ItemType in the database. This History Templates can keep track of different events that may happen to an item such as Add, Update, Delete, etc. Each of these actions can have different comments associated with them. For instance, you may want to track the old and new value for an item when it is Updated.
You can find more information about this history tracking under the Just Ask Innovator menu which you can access from the main grid of your instance under Help > Just Ask Innovator.
Hi, is there a way to bring this history templates information to TOC/History Configuration Search Grid? For example, I want to see, the list of item types/methods/properties with all the history 'add, update, delete, etc', modified_by and modified_on, and able to export it to excel? Thanks!
