Hi Chris, I have followed steps to enable few custom properties to track history. But I don't see these properties in Item-->History page. It only displays default ones. What would be wrong here ?
Hi Yogesh
You can track history of any custom properties by enabling the track history in item type properties tab.
Thank You
Gopikrishnan R
- Yogesh6 years agoIdeator II
Thanks Gopikrishnan, I did that step already but don't see these properties under History page. I also assigned same History Template to all Lifecycle states of that item. How to display it?
- Gopikrishnan6 years agoAccelerator II
Hi Yogesh
I added a property in Part item type and enabled track history. Added the property to form. When I create part and update test property, history is tracked. History template is added in Item type : Default
Thanks Gopikrishnan. I did all the right configurations but was expecting new column for Custom properties on History page but didn't realize changes are tracked under 'Comments' column. It is working for me. Thanks again for the help.
