Administrators can specify History Templates for each ItemType in the database. This History Templates can keep track of different events that may happen to an item such as Add, Update, Delete, etc. Each of these actions can have different comments associated with them. For instance, you may want to track the old and new value for an item when it is Updated.
You can find more information about this history tracking under the Just Ask Innovator menu which you can access from the main grid of your instance under Help > Just Ask Innovator.
- Yogesh6 years agoIdeator II
Hi Chris, I have followed steps to enable few custom properties to track history. But I don't see these properties in Item-->History page. It only displays default ones. What would be wrong here ?
- Gopikrishnan6 years agoAccelerator II
Hi Yogesh
You can track history of any custom properties by enabling the track history in item type properties tab.
Thank You
Gopikrishnan R
Thanks Gopikrishnan, I did that step already but don't see these properties under History page. I also assigned same History Template to all Lifecycle states of that item. How to display it?
- lkartawinata_lear_com2 years agoIdeator III
Hi, is there a way to bring this history templates information to TOC/History Configuration Search Grid? For example, I want to see, the list of item types/methods/properties with all the history 'add, update, delete, etc', modified_by and modified_on, and able to export it to excel? Thanks!
