If I'm understanding the use case right, I don't think this is possible with any of the default fields available from a Form. However, using some custom HTML inside an HTML field, you should be able to get something like this working. You can see this Stack Overflow post for an example of a dropdown that also lets users enter in a value that's not in the list.
Taking this approach, you will need to handle a few things manually. You'll need to have some code populate the dropdown with the existing auditors in your database as well as have an onChange event actually set the value entered on the parent item. You can do this pretty easily with handleItemChange("your_property_name", "Your Property Value"); .
