- eli_donahueCommunity ManagerHi bryantwu, Can you describe your use case in a little more detail? I'm not completely sure what you want to do. If you want to prevent users from creating a new relationship on an item you can configure the relationship ItemType to use a different Permission item than the parent ItemType. Eli
Eli Donahue Aras Labs Software Engineer - Former_MemberAccelerator IIIHi Eli: Thank your help! I want to from the client prevent users from creating a new relationship on an item. Because the permission is dynamic,so I want to from the client control. EX1:User (A、B),Activity(C、D),Tab(E、F) Activity C: A can create E new relationship, B can create F new relationship Activity D: A can't create E new relationship, B can't create F new relationship EX2:IF Form colum A = 'TEST' ,user A can't create new relationship
- eli_donahueCommunity ManagerHi bryantwu, Are you still working on this use case? If so, what version of Aras are you using? Eli
Eli Donahue Aras Labs Software Engineer - michelleCreator IIHi Eli I have the same question. I use version 11SP6
