3 months agoCommunity Manager
Hi Angela,
I have a couple follow up questions.
- Do you need this property visible from the relationships grid? Could you get away with simply hiding that column?
- What version of Innovator are you currently on? I'm going to take a quick poke around a local instance to see if I can track this down, but frontend logic like this tends to be version specific.
- Chris
- angela3 months agoCatalyst II
Didn´t I answer this post? I don´t see my last answer anymore. It contained a screenshot.
I use 12SP7 and I definitely need the property in the relationship grid. :). The file is added automatically. User shall see the value, but never be able to add/edit it manually.
But I already found a solution with a couple of Methods.
