4 years agoCatalyst II
Hi Ken,
I right now cannot remember where and how I used this one.
In one case I faked the item selector by using a Method that calls the Search Dialog manually. So basically I used a regular field in combination with a custom "selector-like" button to open the Item search. This variant worked but didn´t support type ahead.
A better idea would be to open the TOC View with a temporary context item. But I so far haven´t found a solution for this by myself, as you can see in the post from 1 month ago:
KenDiver
4 years agoIdeator I
Hi Angela,
thanks for the answer. I will post here something if I get a solution for this.
