Dharmatej34
9 years agoIdeator II
Hi Jams,
If I understood your problem correctly, you want to have a filter on the items which shows up in the search dialog popup when you browse for an item.
So, if this is what you want, then you can add a property event and attach a method to it, which would filter the result set based on some logic.
Regards,
Dharma
