DouglasW's avatar
DouglasW
Ideator II
4 years ago
Hide a Relationship Grid Column
I have a requirement to hide relationship grid column based on classification.  I looked through the community and only found the following as an example fix but it did not work for me.
Hide Column:
parent.findCurrentRelationshipsTab().document.getElementById('gridTD').children[1].getElementsByTagName('th')[ColumnIndex].setAttribute('style','display:none;');
All it did in Innovator 12 is hide the Header cell for that particular item.
Hopefully, someone has attempted to do this from Innovator 12?
  • Not sure if it will work but did you try to use td instead of th to hide the property field?
