I was able to make some progress on this one. As an alternative to hiding the result(s) if they met the criteria, I changed the text of results on that row to red. The issue is that there is no way, that I have found, for the form to execute the method code in time for it to happen. I only verified it worked by changing “onLoad” or “onFormPopulated” event to “onMouseOver” for a form event and when I moved the mouse the code would fire. The “onLoad” event executes before the relationship tabs are populated. Any thoughts on how I can fire the code with existing form “events” when the form initially loads and each time it updates/reloads?
