8 years agoCommunity Manager
Hi Michelle,
In order to trigger this function on the "gridDoubleClick" event, you will need to pass the function in as a parameter which is done by just passing in the name of the function without any parenthesis like below.
"gridDoubleClick": onDoubleClick
Note that in the above example we did not use 'onDoubleClick(0)' which would cause our double click event to always run against Row 0 regardless of what row was actually clicked on.
__________________________________
