I assume you just get the very plain items without properties. Use the "get" command and combine it with and combine it with a "select" to reduce server load.
Item Man_Part_List = inn.newItem("Manufacturer Part","get");
Man_Part_List.setAttribute("select","item_number");
You liked this answer? Subscribe to my Youtube channel to learn even more about PLM --> PLM Underground on Youtube
Changed the code use "get' command and combined it with "Select". Still didn't worked.
Item Man_Part_List = inn.newItem("Manufacturer Part", "get");
Man_Part_List.setAttribute("where", "[Manufacturer_Part].IS_CURRENT= '1'");
Man_Part_List = Man_Part_List.apply();
It should work. I was able to use this one successfully in my test db:
for (int i = 0; i < Man_Part_List.getItemCount(); i++)
Item cur_man_part = Man_Part_List.getItemByIndex(i);
string cur_man_part_name = cur_man_part.getProperty("item_number"); //cur_man_part_name always returns NULL
return inn.newResult("My test result: " + cur_man_part_name);
- nchagan5 years agoIdeator I
It is weird. I used the same code on my environment and for me it returns NULL.The only change is, am using newError instead of newResult but that should not make any difference.
return inn.newError("My test result: " + cur_man_part_name1);
That´s really weird. Does your "getItemCount()" return the correct number items?
What result do you get, when you directly display the item in an error message?
E.g.
return inn.newError(" " + Man_Part_List);I am little bit confused of your 'where' query. It´s not wrong and should work, I am just curious why you use it. Manufacturer Parts by default are not revised. What happens when you don´t use this filter or replace it with this version, that does the same:
Man_Part_List.setProperty("IS_CURRENT","1");
Is your query part of a bigger query? So for example you also search for Parts and Part AML at the same time?
