eli_donahue
8 years agoCommunity Manager
Hi bdc604,
Something like this may work for you. I tested it in 11 SP12, so you may see different behavior if you're using an older version of Innovator.
var parentItem = parent.thisItem;
if (parentItem.fetchLockStatus() == "1")
// get form context
var instanceFrame = parent.parent.document.getElementById("instance");
if (instanceFrame && instanceFrame.contentWindow) {
instanceFrame = instanceFrame.contentWindow;
alert("alert");
// update the parent property in cache
if (instanceFrame.handleItemChange) {
instanceFrame.handleItemChange("description","test");
else
alert("Parent is not locked, or is locked by another user.");
Note that this updates the item in cache, not the server. If the user wants to save the changes to the server, they'll need to click "Save". If you want to automatically save the changes to the parent and refresh the form, you can do something like this:
parentItem.setProperty("description","test1");
parentItem.setAction("edit");
parentItem = parentItem.apply();
aras.uiReShowItemEx(parentItem.getID(), parentItem.node);
else if (parentItem.fetchLockStatus() == "0")
// lock and update the parent or warn user
alert("Parent is not locked. Please lock.");
else
alert("Parent is locked by another user or cannot be locked.");
Eli
- jancv6 years agoIdeator II
Hi Eli,
We have similar situation where relationship grid js code update parent data and apply them. The code above works perfectly however our parent is versionable and on edit new generation of parent item is made.
So when we use code:
old tab with old generation is still open plus new tab is created with new generation.
Is any way to avoid this and just refresh parent form?
