2 years agoCatalyst II
"State" property cannot be edited this way, cause state is changed due to promotion of the LifeCycle. So what you want to do requires the AML action "promoteItem" and not "edit".
Hargul_Sidhu
2 years agoCreator I
Thanks! Do you know why is the output "<Result/>" when more than one condition is used in the "where" clause.
Also, when the output is "<Result/>" it doesn't "edit" either. If "<Result/>" is just an item the part should at least be edited, correct?
Also, where do I find more information on AML action "promoteItem". I need to see some examples of this or just some documentation outlining the use of methods in AML. Super new to Aras here.
