It is not possible to use a server-side method with Form Events or Field Events. However, you can call a server-side method from within a JavaScript method using code like the sample below.
aras.applyMethod("My Method", '');
The second argument can be used to pass in any arguments to the server-side method that you need.
aras.applyMethod("My Method", "<myArg>My Arg's Value</myArg>");
You can then retrieve these arguments from within your server-side method with a line like below.
this.getProperty("myArg");
_____________________________________________
