8 years ago
forms creation
Hi Everyone, how to set the default sequence order for the item type. how to change the default form relationship.   please help.
  • Hi, Can you precise what you want to achieve? If you have a new itemtype, you will need a property of type Sequence. In the admin folder from the TOC you can create new sequences. If you want to attach a new form to your itemtype, create a new form first and then attach it in the view tab of you itemtype confguration. Hope that helps a little bit. There are quite a lot of info about these configurations if you go in the help menu -> just ask innovator
