In Innovator 9.3 Release Notes, I see that:
Introduced a Variable Item "Aras.Client.MetadataService.Url.Salt" that can be used to force the metadata cache to reload. By increasing the value of the variable by 1, the end users will refresh the metadata cache the next time they log in.
This post and the solution provided by Chris were intended for Innovator 11. I don´t know if the variable is still used or required in Innovator 12+.
Since I use Innovator 12 I never had trouble with cache problems. I only change the web.config counter in case of codetree modifications. That´s it.
Only scenario that can lead to trouble is if user stored the wrong link to an Innovator instance that contain X-salt value or some tokens. This is a constant pain, case users like to bookmark the Innovator link and often don´t read the hints I gave them in the introduction email, to not "star" the link but to add it manually.
How is your experience?
- julien_dufrenne_ansys_com3 years agoIdeator II
Yes normaly update web.config works for client and server sides
