mouad's avatar
mouad
fill in a filtered list dynamically
Hello ALL, I have two list and i want them to be filled dynamically by a method, the first is a normal list and the second is a filtered list. I have already managed to fill in the first automati...
  • Gopikrishnan's avatar
    Gopikrishnan
    Hi Mouad
    Can you try the below steps and let me know if it works
    Step 1: Navigate to Administration --> List
    Step 2: Create new list
    Step 3: Navigate to Filter Value
    Step 4: Fill your list values
    Example:
    Step 5: Create New JavaScript Method and copy below code
    var UpdateListValuesAPI = function() {
    var dropdown = getFieldComponentByName('listeone');
    var teams = aras.IomInnovator.newItem("ItemType", "get");
    teams.setAttribute("select", "id, keyed_name");
    teams = teams.apply();
    var listOfTeams = [];
    for (var i = 0; i < teams.getItemCount(); ++i)
    var team = teams.getItemByIndex(i);
    listOfTeams.push({
    label: team.getProperty('keyed_name'),
    value: team.getProperty('keyed_name')
    dropdown.component.setState({
    list: listOfTeams,
    calculatedWidth: '',
    value: listOfTeams[0].value
    UpdateListValuesAPI.prototype.updateSecondList = function() {
    var selectListValue = document.querySelector("input[name='listeone']").value;
    var dropdown2 = getFieldComponentByName('listetwo');
    var values = aras.IomInnovator.newItem("Filter Value", "get");
    values.setAttribute("select", "label,value");
    values.setProperty("filter", selectListValue);
    values.setProperty("source_id", "38EEFD3D9AB749478495D437D9919D7D"); // TO BE REPLACED
    values = values.apply();
    if (values.isError())
    aras.AlertError(values.getErrorString());
    return;
    else
    var listTwo = [];
    for (var i = 0; i < values.getItemCount(); ++i)
    var listVal = values.getItemByIndex(i);
    listTwo.push({
    label: listVal.getProperty('label'),
    value: listVal.getProperty('value')
    dropdown2.component.setState({
    list: listTwo,
    value: listTwo[0].value
    objUpdateListValuesAPI = new UpdateListValuesAPI();
    Step 6: Replace Source_ID with ID of the above created list
    Step 7: Open Form where your need to use this (example Part Form)
    Step 8: Ensure that form has the listeone and listetwo fields
    Step 8: Add above method in Form Event --> On Load
    Step 9: Create New JavaScript Method and copy below code
    objUpdateListValuesAPI.updateSecondList();
    Step 10: Add this method in field listetwo --> Field Event --> On Focus
    Step 11: Unlock form and test the data
    Thank You
    Gopikrishnan R
