mouad's avatar
mouad
Fill a field when the item is locked
Hello ALL,
Is there any way please to fill a field and save  the item when it is locked.
I have tried the code below (client method with the event onFormPopulated) without success as the item is saved but keeps the field empty :
var lock = document.thisItem.getProperty("locked_by_id", "");
if (lock =='' ){
var field =getFieldByName("_champ");
field.getElementsByTagName("input")[0].disabled = false;
field.getElementsByTagName("input")[0].readOnly = false;
else {
var fields =getFieldByName("_champ");
fields.getElementsByTagName("input")[0].disabled = true;
  • Hi Mouad
    Below on form populate method might help in this case (This will check whether the document is in edit mode and state = "Preliminary"
    var state = document.thisItem.getProperty("state", "");
    if (document.isEditMode && !aras.isTempEx(document.item))
    if (state === "Preliminary")
    getFieldByName("_champ").getElementsByTagName("input")[0].disabled = false;
    else
    getFieldByName("_champ").getElementsByTagName("input")[0].disabled = true;
    Thank You
    Gobikrishnan R
