Jenli's avatar
Jenli
File Checkout function unusual
Hi Team,
I am trying to Checkout/Download the File from CAD operation, here is my code, it seems working fine till line 11, but it finally checkout the file as "vaultserver.aspx"?? Any ideas? Thank you!
  • It finally checkout the file like this,
      "Checkout" is an old concept, I don´t think it still works for Innovator 12. This one is a more modern variant:
      // Get file
      var fileItem = aras.getItemById("File", "1234566....");
      // Download file
      aras.downloadFile(fileItem, "myfile.zip");
      • Jenli's avatar
        Jenli
        Thanks Angelalp for always being here!
        I tried downloadFIle function and turns error. Actually if I change the suffix of "vaultserver.aspx " as it is, such as(.dwg), then open it, which I found out it is the file I exactly downloaded. And now the question is why the checkout file is named "vaultserver.aspx by using checkout fuction.
        Thanks,
        Jen
