didonato
9 years agoCreator II
Federation Data
I'm trying to duplicate the code from an article that was posted in "Knowledge Base" called "Further Example of Federation". After following the instructions and changing the connection to my database I get a " [object Object]" error. Below is my method: Any help would be appreciated. Thanks
// GetOnHandInventory
// Called from ServerEvents of Federated Item ItemType "Part Inventory"
// Connects to external database via OleDb calls
// Populates on_hand_inventory and db_description fields of federated item
// This method updates the grid for the relationship item and is implemented
// as an onGet ServerEvent.
// Get the item_number, it's not passed automatically
Item qry0 = this.newItem("Part");
qry0.setAttribute("select","item_number");
qry0.setID(this.getProperty("source_id"));
Item res=qry0.apply("get");
if (res.isError()) return res;
// get the Part Number (key) that we will use in the external database to search on.
string masterpart;
masterpart = res.getProperty("item_number");
// Connect to external (in this case SQL Server) database
System.Data.OleDb.OleDbConnection myConnection = new System.Data.OleDb.OleDbConnection(@"Provider=sqloledb; Data Source=server; Initial Catalog=Test; Integrated Security=SSPI;");
// construct sql Select statement to retrieve data from external database.
string sqltext = "Select partnum,totalstock,descrip from Sales Where Partnum = '" + masterpart + "';";
System.Data.OleDb.OleDbCommand com = new System.Data.OleDb.OleDbCommand(sqltext);
com.Connection = myConnection;
myConnection.Open();
System.Data.OleDb.OleDbDataReader myDataReader = com.ExecuteReader();
// create a Part Inventory item
Item res5 = this.newItem("Part Inventory");
string newid = getNewID();
res5.setID(newid);
// Call apply on the item to create it in the server. After this is done
// we can populate with the returned information from the external database
res5 = res5.apply();
res5.setProperty("part_number",masterpart);
// Check if there are any rows returned and supply default information
// if they are not
if (myDataReader.HasRows != true)
res5.setProperty("on_hand_inventory","0");
res5.setProperty("db_description","Not Found");
else
// get the data from the dataReader and populate the Part Inventory item>
myDataReader.Read();
res5.setProperty("on_hand_inventory",Convert.ToString(myDataReader.GetDouble(1)));
res5.setProperty("db_description",myDataReader.GetString(2));
myConnection.Close();
// return the PartInventory item to be populated in the grid.
return res5;
