I have a similar usecase than chenze. The main question is probably to use hyperlinks in the grid and not in the Form. In my case I use an additional Null-Relationship for Hyperlinks in the ItemType Part. Users shall be able to open hyperlinks directly from the relationship grid.
I didn´t spent too much time on this, because I expect some kind of hyperlink data type will one day be implemented anyway. This one is my current workaround:
1. Open Relationship ItemType used for storing the hyperlinks
2. Go to
Client Events tab
3. Add new
OnShowItem Method
4. Add the following code
var path = this.getProperty("link_path"); // <- use name of property that stores the hyperlink
window.open(path, '_blank');
This solution overrides the custom form, so it´s only sufficient when you really just store some simple hyperlinks in the relationship grid. Some other options for the Relationship grid would be a custom Action or to create a separate ItemType for hyperlinks (better look&feel).
If there is a solution for a "real" hyperlink properties in grids available, I would be highly interested in it!
