Sathish's avatar
Sathish
8 years ago
Export GridContainer to Excel
We use the Aras treegridcontainer to construct data in a custom UI. Is there an inbuilt API that will enable to export the data that is displayed in the treegrid UI  to excel. Any inputs related to this will be helpful
  • Hello, This may be possible by using the aras.export2Office javascript function. You can see an example of how to use this function to export a grid to an Excel file in the JavaScript Method cui_default_mwt_export2Excel. Chris
    • Pavlo88's avatar
      Pavlo88
      Ideator II
      I`m little bit struggling with this question too. In my case I need to export all rows of the Impact Matrix and indeed aras.export2Office works but impactGrid.grid.getXML collects only 1 level of rows (no collapsed rows).
      maybe somebody knows how to get all rows into xml to be able to export to excel them later on?
  • Hi good question! I would be also interested in this use case. Also I haven´t seen an option to export tree grid content so far. I right now use standard report options to create Excel reports with similar design and content. Angela
