8 years agoAccelerator III
I solved it. The ssl cert i generated for the the site is for the CNAME so if you try and access services from localhost you get the ssl error.
Solution is to use FQDN that the cert was generated in VaultServerConfig.xml :
<AppServerURL>cname.domain.tld/.../AppServerURL>
