NiNi's avatar
NiNi
Error when SQL is specified in "where" attribute in AML
Hi Team,
There is AML that seems to have never been an error before, but somehow it becomes an error.
* Aras version is 11.0SP15.
For example, I remember that SQL could be written in the where attribute like the following AML and IOM code.
At the very least, I was able to execute AML / IOM code written in this way in my previous development (V11.0SP8 environment).
===<AML>========================================
<Item type='CAD Structure' action='get' where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')">
</Item>
===<IOM code>=====================================
Item applyItm = inn.newItem("CAD Structure", "get");
applyItm.setAttribute("where", "[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')");
Item resultItm = applyItm.apply();
However, when I run this on my current development project, I get the following error:
<SOAP-ENV:Envelope xmlns:SOAP-ENV='schemas.xmlsoap.org/.../'>
  <SOAP-ENV:Body>
    <SOAP-ENV:Fault xmlns:af='www.aras.com/InnovatorFault'>
      <faultcode>SOAP-ENV:Server.ItemAnalysisException</faultcode>
      <faultstring><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')"". Incorrect value explanation: "select" is forbidden in where attribute.
Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = 'TestName')"". Incorrect value explanation: Item hasn't property referred to column with name "name"
]]></faultstring>
      <detail>
        <af:legacy_detail><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
Details:
]]></af:legacy_detail>
        <af:exception message='Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.&#xD;&#xA;Details:&#xD;&#xA;Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = &apos;TestName&apos;)"". Incorrect value explanation: "select" is forbidden in where attribute.&#xD;&#xA;Incorrect value: "where="innovator.[CAD_Structure].source_id in (select id from innovator.[CAD] where name = &apos;TestName&apos;)"". Incorrect value explanation: Item hasn&apos;t property referred to column with name "name"&#xD;&#xA;' type='Aras.Server.Core.ItemAnalysisException' />
      </detail>
    </SOAP-ENV:Fault>
  </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
I get an error message saying that "select" is forbidden in where attribute.
I've seen errors like this for the first time.
What should I do?
Is there something wrong with the syntax ? Is the Aras environment bad ? Has Aras AML / IOM rules changed ?
Regards
  • Hi NiNi,
    a security update in one of the version 11 Service Packs made it so that you cannot simply use all sorts of SQL in where-clauses any more. You will need to work with whitelists to re-enable this. See this community post for further details. I have never used it myself, I simply remembered the linked community post.
    Cheers,
    C
  • Hi NiNi,
    Cheers,
    C
    • NiNi's avatar
      NiNi
      Hi cogres,
      Thank you.
      I finally understand the reason.
      It is described in "Aras Innovator 11.0-AML Security Settings.pdf".
      In V11.0SP9 or later, the use of SQL in AML on the Clinet side was restricted.
