Error uploading File
When attempting to upload a file to the vault, the application hangs and the error log on the server returns Unable to connect to the remote server. This was working until recently but I am unsure what would have changed. Has anyone else experienced this issue?
Thanks!
  • A little more information. There is an unhandled exception that is being thrown as well that is: SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:80
    Any help is greatly appreciated!
  • Hi Mrunal, I was able to fix the issue by running this command on the command line of the server:
    netsh http add iplisten 127.0.0.1
    Hopefully that helps,
